Wireless Arlo security camera
Works here on multiple devices. Have you rebooted the phone and reinstalled the app?
Still cannot view recorded video in full screen on my Samsung android phone
Just tried on my Galaxy Tab S3 to keep it Samsung and had no problems. I had it in portrait mode, started viewing the video and then rotated the tablet to landscape which resulted in the full screen view. If you mean it doesn't actually fill the screen, that's different and is a result of a combination of the app, video aspect ratio and screen aspect ratio.
Hi @jguerdat This issue is on my Samsung android phone.I do not have a portait mode.There is not an option for full screen after it was updated.
Portrait mode is holding the phone vertically (normal). Landscape simply means physically rotating the phone 90 degrees. When I do that, the screen switches to full screen since the app is trying to fill the screen horizontally. Note that Android provides the ability to block or allow this switching so check your phone display settings if this doesn't work.
@jguerdat I do not have this option in my display settings on my android Samsung model #SM-J337A phone.I still cannot view a full screen recorded video.Even when I rotate my phone.
While it sounds like a phone setting issue, what do you see when you rotate the phone? Does the display change at all?
Just checked on my Samsung tablet and I can't find a rotation setting, either. However, it DOES rotate the display between portrait and landscape with no problem.
When I rotate my phone nothing happens.It does not show full screen on the recorded video.Keep in mind this happened after the Arlo app was updated.Samsung Android phone
I'm tempted to say that a factory reset of the phone may be needed but I'd contact support here first just in case.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy924
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,067
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
