I Give up, batteries drain too quickly
That makes it sound like you have Pro cameras, not the original wirefree that this section is about.
Was the base turned off in that time? The cameras will try to connect during that time, depleting the batteries quickly.
Smphillipstx
Same problem with one out of four cameras. Been working perfectly (indoors) and all of the sudden, has battery drain problems. Batteries last leass than 2 minutes - get low battery warning. Bought batteries from several vendors thinking maybe a bad batch, did the factory reset, etc - no avail.
Model: VMC3030 | Arlo Wire-Free Camera
ananth-6
I have a Tenergy T333 battery tester which I use regularly. When Arlo says my batteries are at 2%, the battery tester is showing full bars! That means batteries are still good. I have pile of expensive CR123 batteries rejected by my 4 ARLO wireless cameras. Unless you are looking for expensive paper weights, these ARLO cameras are of no use.
MattB21
We purchased a 4 camera Arlo Pro system in January 2018. We typlically Armed all 4 cameras in the evening and Disarmed them in the morning. Then in late May after leaving them Armed while we were away for a 4 days, the batteries started discharging 25-35% per day whether they were Armed or not. Tried everything including checking to make sure we had the latest firmware update which was last done June 8.
Still trying to get hold of customer service to get them replaced on warranty.
Model: VMC4030| Arlo Pro Wire-Free Camera
MJ23
Well, when i first bought tge cams, ofcourse while reading uts feature and experiencing them, the battery lasted for about 4 months. I satrted getting the low abttery warnings, and immediately i jumped into action and recharged them, one by one. I have 5. All with oerfect signals except 1 with one bar the. All under the balanced whality and batt life option. My app and cam are all uptodate.. Anywho, after charging them, they lasted about a week and now one by one they are all going low on battery. Why? What can i do? Read somewhere open and close thge battery compartment or reset the abse station. Help plz...
New Base station firmware has been released that should help resolve the issue being discussed here. Check your base station firmware to be sure you are up to date with the latest available version.
Take a look here for more information on this firmware: Firmware Release Scheduled 6/21 to Address IR Rapid Battery Drain and Modes and Schedules Issues
MattB21
Thanks James. Since the draining problems began, have had two firmware updates, the latest 06/19.
Will see if that and the latest update (09/21) fixes the rapid draining of one of my cameras which is still draining quickly.
