Best answers
https://www.arlo.com/en-us/support/contact
This is basically the only way...do not be fooled by google search sites which are usu a scam ( there is no phone number to call )
You can use Settings, Support if you have a subscription and/or tell us all details of your issue(s) - we may be able to help.
If you have a subscription, there is a phone number in the App support settings. You could get one then cancel it as you should get the unused part back or at worst be charged a month.
