How to fix my Home WiFi Network from regular disconnecting? Tried restarting laptop.
  • 1926 Views
varonica_1
For the last 3 or 4 days, my laptop and Arlo camera is randomly disconnecting from my wireless network. It is shocking for me that other devices connected with the same network working fine.
I restart my laptop which fixes my problem, but I get disconnected again. There is any fix
Bishwa4
1. Press Windows Key + R then type devmgmt.msc and hit Enter.
2. Expand Network adapters then right-click on your installed network adapter and select Update Driver Software.
3. Then choose Search automatically for updated driver software.
4. Reboot your PC to save changes. If the problem still persists then read WiFi Keep Disconnecting
How are you using the laptop... rebooting the laptop should have no effect on the base staying connected ( unless they are fighting over the same ip address )
Bishwa4
It's possible that it's just a display issue. When "disconnected" what are the LEDs on the base showing? Refreshing the page (which causes a new login) may clear the issue, meaning it's not really disconnected, especially if the 3 LEDs are all green.
You can also try the app to see if it displays/works differently.
