10 seconds is not long enough for me. How can I extend the recording length when motion is detected?
There are no settings under "rules" that allow adjustment of recording length. But in the forum I've seen people saying there is. Are they talking about Arlo Q instead of what I have (Arlo wireless)?
Or is there a way to change settings that I have not been able to discover?
yes recording length can be set up to 120 sec.
go into the mode you are using, edit the cam you want to change and under record video you'll see a slider to set the length
So I have a 4 camera system, 5th camera didnt work but beside that I was curious why ( and if it can be changed ) once arlo senses motion if you can have it record for more than 10 seconds. Theres times ill only see 10 secs of activity at my house because thats only how long itll record for. So can this be changed and if so how.
You do it under your modes settings,
https://kb.arlo.com/1079027/How-do-I-adjust-Arlo-video-recording-length
