How to connect arlo base?
  • 3880 Views
KoknoNobu
I try those instructions. But still can’t. Connect.
To reset your Arlo SmartHub or base station:
- Unplug your router for 10 seconds.
- Enable Bluetooth and cellular data on your smartphone.
- Connect a Wi-Fi cable to your base station.
- Use a pen or straight paper clip to press and hold the reset button on the back of the device for about 10 seconds.
- Release the reset button.
- When the reset is complete, the LED on top will turn orange. When the LED stops flashing orange, your Arlo SmartHub or base station will restart. Once the restart is complete, continue with the installation.
To connect your Arlo SmartHub or base station to the Internet and add it to your Arlo system:
- Launch the Arlo Secure app.
- Tap Add New Device.
- Tap Base Station/Hub.
- Connect your SmartHub or base station to your Wi-Fi router using an Ethernet cable. - Note: Before you power on your SmartHub or base station, you must connect it to your router with an Ethernet cable. If you power it on before connecting it to your router, your SmartHub or base station may not connect to your network.
- Connect the power adapter to your SmartHub or base station and plug it into a power outlet.
- Some older base stations have a power button. After you plug your base station into a power outlet, press the power button to turn it on.
- For a SmartHub or base station with one LED, power it on until the LED is solid blue.
- For a base station with three LEDs, power it on until the power LED on the front of the base station is solid green.
- Follow the in-app instructions to complete the setup.
Best answers
  • StephenB
    Is this a new installation?  Or are you re-installing.
    What country are you in?
Where in the process does it fail?
KoknoNobu
Hello
its already beginning there the potion not flashing orange light.
And after that I just keep continue but not upload basement.
Please help me.  I’d like to beginning model. My machine is still good.
I don’t understand why can’t reupload.
