Where is the view (say 130 or 180 degrees)?
when i first bought the product and when settings done on line & not thru an App, could have sworn was able to adjust the field of view in both detection and recordings.
Thx. Found the setting. It was right there in front of me. I do seem to recall in an earlier version, that under the image had the word zoom and a bar to move in and out. Also that though the view wider than 130.
On Arlo, Pro a, and Pro2 the angle has always been about 123-130 degrees.
Tho the view can be cropped/zoomed smaller in the video settings
Only on the newer cameras is the FOV adjustable ( also on the Q and Baby (IIRC))
