How many cameras can I sync to VMB3000 Base Station?
How many cameras can I sync to this base station?
I've been told that the 15 "limitation" is a practical one, not theoretical. A big issue as you add cameras to the base is that you can only stream 5 on the same base at a time so adding more may cause you to run into that real limitation more frequently.
