How do I turn on only one camera
  • 1 Reply
  • 4032 Views
JDCRITES
You need to create a NEW MODE.
Go to MODE, click on Arlo base... left side bottom is ADD MODE.  Click on that button and follow the steps.
Lable the new mode for the camera so you know what it controls..the default DISARM mode will be use to turn the new mode off.
Tips :
Any camera not in a Mode will be OFF
Only ONE mode can run at a time
To add a second ( or more ) cameras to a new Mode, create the mode , then go back and EDIT it adding the next camera
