I recently bought Arlo system and I use iOS. When my iPhone (or iPad) starts the "Do not disturb" mode, Arlo can't "alert" me. I receive the email but not the sound or alert during night for example. Does someone have the same problem/ or the solution? Thanks. Sorry about my English.
Isn't that the whole idea of Do not disturb?
It is suppose to stop FaceTime calls and Alerts when on...only exception is certain calls if you allow.
So it's working fine, theres no fix for that
There are a lot of apps that could run with "Do not disturb"mode.
You should try some...For example: Baby Monitor 3G, has a great function over the mode, and the app run properly.
I think that there is solution to fix this problem.
I'm not saying that it couldn't be done... just that it isn't built into the app to over-ride the Do Not Disturb.
As is, the iOS is doing what it says it does.
You could post it in the exchange section ; https://community.netgear.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange
