How do I connect my Arlo base station to the Internet?
The base connect directly on the router wireless
My phone mobile connect on the router wireles not the own wifi of the base because for this wi fi ask the password
and I d ont know
Please help me
PS. I try and a registered the serial number of base but I deactivate , big mistake
Hi Alexander,
You do not need to connect your mobile phone to the Arlo base station. Only the Arlo cameras will have to connect to it. Just be reminded that your mobile phone should be connected to the SSID that is being broadcast by your existing wireless router.
The Arlo serial number should automatically be discovered and populate in the "Base Station Serial Number" field. For this to happen, make sure you are registering the Arlo system while connected to the same local network as the base station. Check this KB article below:
Please let us know if you need further assistance.
Regards,
DaneA
Arlo Team
