How do I connect a second base station at a second location.
  • 1 Reply
  • 5143 Views
DawnaH
I have an Arlo Puls in by home.  I want to connect a second base station for a reg Arlo at my mom's house.  I need all cameras to send video to only one smartphone.  Is this possible?  I've tried added the second base station from both my home and from my mothers home.
Streak2
Master Master
Yes this is all possible.
If the total number of cameras is 5 or less then you can just add the second base to the same account and sync the cameras to the base. Does not matter where it is located but you must be on the same network as the second base to set it up and sync the cameras.
If the total number cameras is more than 5 then you would need to register the second base using a second email address and then grant your email address access to the second base or do everything using the same email address but subscribe to one of the Arlo paid plans.
All cameras will then appear in the same app. Alerts can be sent to any email address that you nominate.
Streak2
Master Master
