How can I find someone to install my cameras?
  • 1 Reply
  • 3046 Views
HelloNew
Do you install your security cameras if not how can one find someone to install them. Also if the camera is high enough to need a ladder to install are there any cameras which either do not have batteries or which the batteries can be changed or recharged without having to climb up on a ladder
There are some third party companies that install the cameras/system ...like Geeksquad ,etc
All outside cameras at this time run on batteries...but if you wait a short time, the PRO camera is releasing a solar panel to charge it while outdoors ...this will require very little maintenance once running.
As to the ladder, it's mostly to keep out of reach...
The other option is to use a Q camera thru a glass window ( the Arlo. Arlo PRO don't work thru glass ) as it's an inside camera and ac powered ( just turn off the illuminators )
