I have very busy cameras (I use them for wildlife and bird watching). When I open the new app I want to be able to see the feed from a specific camera. I do not want to have to scroll through the feed from all 4 cameras just to see the feed from one. In the old app I could do that. Now I can’t figure out a way to filter the feed by camera. Am I missing something?
Any help is appreciated.
Shelley
- Press on the three dots on the top right of the "feed" page
- Select "Feed Settings"
- Select "Devices"
- Choose "Deselect All" and then select the desired camera.
This is "sticky" - meaning the filter will remain in force until you go through this process again to change it.
- Select "Devices"
A quick way that doesn't involve changing settings is to simply click on the camera thumbnail in Devices (or Dashboard if you have a widget installed). Don't click on the live view button or the settings gear, just someplace else on the thumbnail. That will then show only the videos for that camera.
Thank you! Works great! So helpful!
Thanks jguerdat! That works great on my iPhone but not on my iPad. It is fast and very helpful.
jguerdat - I stand corrected. Your fix does work on my iPad - in portrait mode just not in landscape. Great fix. Thanks again.
