How base station can connect without Lan cable?
  • 22750 Views
ZapppHKCS
Arlo pro 2 camera
I read that the base station has to connect via Lan cable? is that possible connect with WIFI router directly?
thanks
There's no way to use WiFi all by itself - the base has to be connected via Ethernet. Use a WiFi extender to connect to your WiFi and then use the Ethernet port on the extender to connect the base. This has worked great for many folks.
steve_t
Master Master
The base station needs an ethernet cable connection. If you need to position the base station somewhere far away from your router, consider a wifi range extender with an ethernet port. Something like this would work well
https://www.amazon.com/NETGEAR-AC750-Range-Extender-EX3700-100NAS/dp/B00R92CL5E/ref=pd_sim_147_4?_en...
ZapppHKCS
Thanks for your information.
As we haven't the ethernet cable in that mall Wifi only here, any way to settle it just under Wifi Channel?
