  • 5589 Views
Rolandsg
Attempting to connect my Netgear VMB3000 to my Verizon MiFi Jetpack Hotspot that has no ethernet port. There are two socket inputs to the Hotspot: 1) Mini-USB Power, and 2) USB-2 Data. How is everyone connecting or "syncing" the Base and Hotspot with cabling? Both sockets CANNOT be used at the same time due to a sliding blocker!
BTW, since my camera is currently synced to the Base, is there any way I can look at one of the USB connections on the Base and see Camera output just over the my LAN until I get fully WAN through Internet?
Since you need an Ethernet port so the base can connect, use a WiFi extender that's connected to your hotspot. Connect the base to the extender Ethernet port and all should work fine.
Rolandsg
Thanks but the exact problem is how does one CONNECT the WiFi Extender (WN3000RPN3) with Ethernet Socket to the Verizon Jetpack that has USB and mini-USB Power Sockets only?
Via the hotspot's WiFi. An extender connects to the WiFi network that already exists.
