One of my Arlo wireless camera went completely dead. It won't start with new battery either. Is there anyway to reset it or figure out the problem.?
There is no reset for the camera other than removing and replacing the batteries.
Do the batteries slide in easily or are they a little tight?
Place each of the 4 batteries in their respective cavities but do not force them all the way in.
Then gently close the battery door and let the door seat the batteries to the right depth.
