Home
  • 4 Replies
  • 3110 Views
baddreptiles
I have the old system vbm3000. I can't get it to connect.  I have 3 lights on the base.  Power, world with erow and camera.
What colors are the 3 LEDs? Power and Internet have to be green and Camera may be off or solid amber.
baddreptiles
baddreptiles
Yes they are.  I havn't used this in years.  I thought I needed to have a app first before.  I can't get any connection, it just keeps trying.
It looks like all 3 LEDs are amber - that's a problem. It could be the power supply or the base. You can use a voltmeter to check for 12 volts DC at the power supply connector - if it's ok then you have a bad base.
