Help setting up the ARLOVMB5000 smart hub
  • 1 Reply
  • 726 Views
Retired_Member
Not applicable
I am looking for a link that will lead on instructions for setting up the ARLO VMB5000 smart hub. Any suggestions would be greatly appreciated.  Thank you.
There should be a quick start guide in the box.  If you've misplaced it, you can download it:
Start by connecting the smarthub ethernet to your router.  Then go into the Arlo App, and add the base station using "Add device".
