Help Stop Recording Parked Car?
  • 1 Reply
  • 2631 Views
bluepanda29
I have a parked car in my driveway that keeps being detected by the camera. Now I was able to turn off the alerts for vehicle detected, but whenever I check my video library there are still a ton of short recordings of that parked car being detected. Thus, my battery on that camera getting drained much faster than my other cameras. I can't adjust my recording zone to ignore the parked car as it's near a side entrance that needs to be covered.
Basically, I want to know
Is there a setting to ignore all vehicles so my camera won't record cars?  I can't find any setting like that.
Thanks in advance
Prob not... the car is being recorded more than likely due to IR reflection
You can maybe change angle of the view.
With Smart, it will still record as the determination of the object is made at the far end before a file is created
