HUB VMB4540r3 PROBLEME CONNEXION INTRENET VIA STARLINK
BONJOUR
J AI CHANGE D OPERATUER INTERNET JE PASSE AUJOURD HUI PAR STARLINK JE NE PEUX PAS CONNECTER MON HUB PAR CABLE ETHERNET. COMMENT PUIS JE FAIRE POUR LE CONNECTER PAR WIFI A STARLINK ET AVOIR ACCES A MES CAMERAS ?
MERCI BEAUCOUP D AVANCE
MME ROURE
Starlink does have an ethernet kit you could purchase (you'd need to contact them to get the details).
The other option is to purchase a wifi extender with ethernet out. Pair the wifi extender with your starlink router, and then connect the hub to the extender's ethernet port.
