Trying to grant access to family to view cameras but keep getting same error
6 REPLIES 6
Have you tried to grant access through the Web Portal? Do you receive the same error message?
I tried on mobile phone, tablet and on pc through the web. Chatted with tech support for over an hour with no results.
What firmware version is your base station running?
Here is the specs
Have you tried test adding a different email by chance?
I have used multiple different emails as i was advised. The screen appears that it sent the request but the other person does not receive. I set the white list to the 3 domains i was given to allow emails not to be blocked. No change.
