I would expect this from other companies but from netgear???? Think it's time to get my money back!!!
OK so we finally get Arlo which we were excited about. We have 3 people in our house and well this system should be able to be armed and disarmed when anyone of us comes and goes.......or so you'd think.
NoHelp, SayWhat?
Set up IFTTT:
IF first family member arrives HOME then disarm arlo (Using life360 and arlo)
IF last family member leaves HOME then arm arlo (using life 360 and arlo)
3 IPhones set up with life 360 which have been working for the last 2 years
Member #1 comes home alone - Arlo disarms
Member # 3 comes home alone - Arlo disarms
Member #2 come home alone (the member that set everything up) and we have motion alerts going off left and right.
Yes, I set up everything the way it should have been set.
Search for Support number.... can't be found but find "Live Chat"
First support person is of no help and disconnected
Second support person gives me phone number and advises me to set up Geofencing and walks me through steps. Tells me THIS WILL WORK!
Call Support (Speak to someone in the Philippines ....... WHAT?? No USA Support????) And after being on hold get disconnected
Member #1 comes home alone - Member #3 gets 14 motion alerts even though the app says that member #1 is "IN THE ZONE" which means the system should have disarmed. Nope, Not my Arlo!
Look online for the Support chat and it's nowhere to be found but today, the phone number is there (crazy)
Call Support again.... yes, another person in the Philippines (nothing against Philippines but why no USA support???) This person knows nothing about how to fix this and suggests that I (member #3) remove myself from the system all together (Take my name, number, everything off the website, take the app off my phone) and this should help...... Ummm..... WHAT????
So I have to completely remove myself from everything just so I won’t get any alerts on my phone? Instead of someone coming up with a way to arm and disarm this system when different members of the family come and go??? Nope, not working for me!!!!! Support person asks me if I mind being put on a 5-7 minute hold? Um.... again... WHAT???? No. Im not going to wait 5-7 minutes.
Yes, Support person puts me on hold anyway and there I sit for about 15-20 minutes listening to some horrible music when CLICK....... Disconnected!
Can you even imagine how happy I was at that moment???? Yea, not very happy.
So here I sit, with all three members in the house and my phone flashing on and off.
GEOFENCING AT HOME IS NOW HOME MODE
GEOFENCING AT HOMOE IS NOW AWAY MODE
MOTION DETECTED ON PORCH
MOTION DETECTED IN LIVING ROOM
MOTION DETECTED IN BASEMENT
Back to manually arming and disarming.
Arlo is a failure.
These are also in addition to the normal motion detection alerts, which I am also still getting even though my wife is home.
So I've just given up on geofencing entirely at this point... Configured my schedule mode so we're covered most of the time without having to manually change it... Likely won't be buying an Arlo again, unless there's some miracle where they actually address this issue!
Yes I believe this update has fixed the geofencing for me as well. Thanks @JamesC
My geofencing started working just before the app update came out. Seems like something in the cloud was changed and the app update solidified the solution. Both our phones are now updating with in and out of zone status appropriately and the geofencing status is changing to away and home properly now.
Interesting, I just saw a reply on another similar thread with someone saying they got a response from L2 support that engineering still has not fixed the issue, and they will provide an email update once they have more information... Has anyone also been getting a push notification (on android) that won't go away saying that something is playing? for example mine says "Living Room is playing" with a pause symbol next to it, because i named the camera Living room. I can't dismiss it, and when I press it, nothing happens....
One Last rant, seems like they are updating their site, and it's been super buggy the past few days.. the menu bar covers other buttons at the top, this comment screen i'm typing right now only show's one line at a time.... isn't there any testing done when you make updates to your websites? ?
IFTTT DOES work with location on Android. My camera arms/disarms every time I leave/return home. But it surely would be nice if the Arlo app it self would do the job.
@Snn5wrote:
IFTTT does not work with location. Not on Android. You can only vocally tell it to arm or disarm manually.
I only have an Android (Samsung Galazy S7), and IFTTT and location works flawlessly and my Camera arms/disarms everytime. But I only see this as a temporarely solution, as I hope/expect the Arlo app to be fixed....some day.
Geofencing has never worked properly and has always been erratic even with location set to always on. Sometimes it arms and sometimes it doesn't as well as it arms at it odd times when I'm in the zone and disarms when I'm out of zone this also goes for the iPhone as well.
We have tried logging in with the same account as well as separate accounts and granting access to each other. Nothing has seemed to work thus far.
Using IFTTT sometimes I get the notification that it arms and disarms and sometimes I do not. Sometimes IFTTT applet changes geofencing to Armed or disarmed and I get the error message from Arlo to check my geofencing status and settings because they have changed.
So far the only thing that works is using either the manual IFTTT applet widgets to manually turn on and off the system or to go into the Arlo app and click through several men use to arm or disarm.
I knew there were several threads on this topic of geofencing not working for the past couple years but all of the chatter seems to have died down so I don't know if everyone has fix their issue or if Netgear has fixed the app issue or if everybody has just given up.
I have not seen an app update in several weeks. I know that Arlo And Netgear are going through some sort of split however that doesn't justify the lack of support as of late.
Arlo support has been of no help because there are so many variables between devices that have access and the settings used to control access that it is very hard to pinpoint exactly what the issue is and how to rectify it.
It also does not help that each time I try to contact Netgear support it takes 3 days to get a response and it's the usual scripted try this that you've already tried or try that that doesn't work.
The app has been uninstalled from both phones and reinstalled as well as removed devices and reset up the entire system. At this point I have no idea what to do since I am past the point of product return to the retail location from where I bought it.
Can someone enlighten me as to a fix or an update or any news at all?
I have seen that ios 11 has been causing some issues ( not sure if here too ).
But to be honest, When using more than one phone the Geo seems to start having issues.... I've found it to work well when using one phone.
Why, unsure as there are many variables.... But do a check that the gps runs along with the app in the background AND also check to make sure the power saving functions are toggled off for those apps
I've been home for 45 minutes. I've gotten 27 notifications letting me know I'm walking in the living room. I checked the geofencing settings, and it shows me in the zone. But it is still armed. Why won't it disarm. This has been going on for about a week. Rebooting my phone sometimes gets it to disarm, but not every time.
Ivr got a Samsung note 8. The accuracy of the GPS is good with it. Right now it looks like it's got me pinned right in the seat I'm sitting in.
How can I get my arlo to disarm while I'm in the zone? It used to work better.
As far as geofencing goes...do you guys set arlo to geofencing and let IFTTT control or set to Arm or Disarm? I have only one mobile device with access now.
If I leave the area or come back sometimes Arlo tells me my geofencing setting have changed and to resync. Like maybe IFTTT changes the location instead of just turning on and off.
@Snn5 wrote:
I'm trying IFTTT. I use the on off widgets for fastest arm and disarm.
If you use IFTTT, alro will be either armed or disarmed, the geofencing in the Arlo app won't be used at all, since it'll be IFTTT that will change arm/disarm states using the Arlo IFTTT web interface.
Just start IFTTT, go to "My Applets" (bottom right button) and hit the plus sign (top right next to setting).
It will show a text like this :
if
+this
then
that
tap "+this", then chose location, then chose "You enter an area" (you'll have to do this whole thing twice, once for when you leave). Define where that area is (your home I suppose), then tap on the check mark (top right) and you'll be back at the text :
if
(location sign)
then
+that
This time tap "+that", then scroll and search for Arlo and when you tap on it, it'll present 3 options "Arm, Disarm, Start recording". Since we're in "when you enter an area", chose "Disarm", then tap on the check mark (top right) and it'll show you the Applet you'll just have created. You can chose to be notified whenever this runs (if you want it to be like Arlo app, flip the switch to on). Edit the title if you want to change it and tap finish.
Now redo the whole thing with "when you exit an area" and "arm" as the Arlo action to perform.
You should be good to go now.
JP.
Note: You'll likely be presented once to log in to your Arlo account (didn't ask me this time as I already granted IFTTT access to my Arlo account). That should be when you first select the Arlo action.
Now to be clear this only has to do with my phone on Android and does not affect the other phone on iOS correct?
Do they still need access and do I need to Grant access to my device in Arlo or how do I set up the Arlo options for Access granted?
