Geofencing Battery Drain
If anyone is able to test with Ultra that would be great.
I see almost no battery drain from Arlo with Geofencing off.
With Geofencing on I have seen Arlo using more than 70% of battery. An example from this morning is attached.
LG G6 on 8.0.0 VMB3000 + Arlo/Pro Cameras + App 2.7.9_25600
I ran without Geofencing for 24 hours and the Arlo app is not even listed in App Usage - no battery drain. Below is with Geofencing Activated. Horrific battery drain. I will run more tests. Please add to this thread if you are seeing this problem or have ideas to mitigate.
There are plenty of apps that manage location updates without draining the battery. It can be done.
Geofencing struggles to stay updated even when excluded.
Anyone else seeing similar drain from Geofencing ?
There have been many improvements to Geofencing and overall improvements to both apps in recent weeks. Are you still experiencing an issue with battery drain?
I'm experiencing the exact same thing. If it was possible, I would return my horrible Arlo system. Bought it 1½ years ago and the cameras have always been good, but the App is CRAP... Really Awful. Either geofencing is buggy to say the least; or Arlo is eating up half of my battery.
Hire some skilled developers, because so many other apps handle geofencing easily without the drain
Without Geofencing - no battery drain. With Geofencing the Arlo app uses more battery than any other app on the phone.
I developed my own Geofencing solution using Tasker that has almost no battery drain. It can be done if you know what you are doing.
I would highly recommend that Arlo implement the WiFi SSID solution for Geofencing (if you are on your home wifi you are home). This was suggested years ago. It is much more reliable and uses almost no battery.
Why is it that Arlo do not listen to their customers.......
