Firmware Update shut down my wifi
I just set up my arlo hd system last night. Synced the first camera and it worked great for 10 minutes. Then I got a message on the app that a firmware update was available.....choose update or cancel. I hit update and it did nothing and immediately shut down my wifi and said the camera was offline. Why would this have shut my wifi down? I'm almost afraid to try it again!
Do you mean your home network WiFi or the WiFi between the base and cameras? What are the LEDs on the base showing? WHat have you tried? What devices were getting the update? Have you rebooted your router and base?
I suspect it was a brain fart on the part of the base or router that was a one-time occurance.I would turn both the router and base off and start them up in that order. Verify that your WiFi is good. If the base still says an update is available, try again. Theoretically, there's nothing that the base can do to hurt your network but a hardware issue is always possible. Try it and let us know. Worst case, you can swap the system at the store if it happens again.
ANd, no, Arlo won't slow down your WiFi when properly working.
