Extra batteries 50% defective - maddening support
I experienced 50% defective rate on xtra batteries, and maddening experience getting them replaced. Ordered 2 standard, then two XL batteries for my Arlo Pro cameras. 1 std and 1 XL were defective (won't hold a charge).
In both cases, chat based technical support - which I believe is outsourced to Ada Support Company - ran me through maddening algorithmic questions which made no sense for accessory orders to use with cameras working fine for months. They did not seem to grasp my complaint or have access to the accessory order details and required sending the same info over and over. They finally gave up and agreed to send replacements when asked "are you going to replace this or not" with frustration expressed.
The products - except for xtra batteries - have worked great and are easy to install and manage. However, tech support - at least for accessory orders is poor, and quality control - at least on batteries - is also a problem.
bt2058,
What behavior are you experiencing with the extra batteries that suggests they are defective? Could you provide more details?
“Suggests” Lol. The two defective xtra batts would not hold a charge. Check tech support chat records for more details.
and…I stated the same in my original post:)
