E-mail alerts
How can e-mail alerts be eliminated but recordings still occur on motion?
NitroBones,
E-mail alerts are not a requirement for motion detection/recordings to occur. You can disable e-mail alerts by navigating to Settings, and then to Rules. You will then want to uncheck the Send e-mail alert feature for each camera that you do wish alerts to be sent from. Be sure to click the Save button in the top right hand corner of the screen after you have finished changing these settings.
Once completed the camera will no longer send e-mail alerts when it detects and records motion.
