Doorbell Camera
Retired_Member
Not applicable
2026-07-27
04:57 AM
Can't log into app on my Apple phone. Email address and Password are correct.
When I press log in Verification method removed.
When I click on Verification Methods, none work.
Can anyone help please. Thank you.
Were you able to login or are you still seeing this same behavior? If you are still unable to login please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
