I am considering purchasing an ARLO System, though I only have a 5G network. Will the Base Station work on a 5G platform?
@Rodom wrote:
So, just to make sure, it will connect to my 5G wifi router?
The VMB5000 base connects with ethernet to one of your router's LAN ports. It doesn't matter what your wifi is, it will work even if the wifi is totally turned off.
So it will connect fine.
Note the VMB5000 base is not the same as the home security system - that is a different product.
The base station connnects to your router with wired ethernet. It then creates its own closed wifi network for the cameras (you cannot join this network or manage it). So it does not require 5 Ghz wifi.
If you actually mean 5G mobile data, then the base station cannot connect directly to that.
StephenB,
Thanks for your response. I am actually refering to my wifi network, not my cellular/mobile data. As long as I can connect the security system to my 5g router I will be good to go. So, just to make sure, it will connect to my 5G wifi router?
Thanks.
Thank you. I appreciate your help.
