I purchased the Arlo Wireless 3 camera system (VMS3330W model) and I just purchased an Arlo Pro 2 camera as an add on and am waiting for it to arrive. I was wondering if CVR on this Pro 2 and the full 1080p resolution would be supported on this old base station.
Also, when I try to look up CVR plans, I don't see them anywhere. I only see the 30 day or 60 day smart plans. Will the CVR plan automatically pop up and be visible once I receive the Pro 2 camera and connect it? Because i can't find it anywhere right now.
The free plan is based on the total number of cameras in your account so the 3 existing and the new Pro 2 fits in fine.
However, CVR isn't stored like your motion recordings. It's a separate service that has to be subscribed to. You would go into your subscription in Settings and subscribe to CVR for 1 camera and add the Pro 2 to it.
Yes. Don't forget the Pro camera has to be plugged into power.
Or would I have to upgrade to a plan....and which plan would i need? Because currently, i don't see any "CVR" plans listed anywhere on the website.
