Does Arlo products support outdoor AP?
  • 1 Reply
  • 2489 Views
Joala
Hello, I would like to know that if the Arlo wire-free camara products support any ourdoor access point. I want to use these movable wire free camera for specific task within the factory. (which the range is around 700m long). So, I have to use outdoor APs (multiple spots) along with fiber optic. Does the product support outdoor AP like https://www.ubnt.com/unifi/unifi-ap-outdoor/. If anybody has some solutions or advice, please do not hesitate to help me out.
Thank you
Jinn
steve_t
Master Master
Arlo wirefree only connect to the base station, as do Arlo Pro.
You might find Arlo Q cameras suit your needs, as long as you have a power point where the camera needs to go
