Do not want to receive e mail alerts
I went into rules and selected "none" in notifications, yet the e mails are still coming thru!
Tuffcookie wrote:I went into rules and selected "none" in notifications, yet the e mails are still coming thru!
Not to make light of it, but after toggling OFF the check mark for emails, did you remember to hit SAVE on exit? ( also OFF for each camera ? )
I went back and noticed the print was still green so I made sure it was black and pressed "save".
It worked that time!
How you Off for each camera ? dont see this option
Hi Arik,
In order to turn off notification per Camera, please
navigate to the Settings Tab
select Rules
select the Camera you would like to edit
at the bottom of the list there is an option stating "Send email alert", uncheck this box
click SAVE
Hope to hear back from you!
Regards,
NhanN
Hi.
I try to un-check this box and it wants to delete the whole rule! What am I missing?
Nevermind. It's deceiving because "delete rule" moves up. I clicked on "save" and it worked.
