It looks like the Arlo 2 Pro will work with the original base station but will I also have the ability to record for a longer period as well as see 3 seconds before it trips to record? I don't have these options with my current version.
The Pro2 will fiunction with the original base,
The 3 second look back is only if the camera is on ac power ( as it is always recording and then add 3 secs to the front of a trigger event )
You do not get the siren and the usb backup as they are physically on the newer base units ( Pro/Pro2 )
