I am away on vacation and the Alro system says its off line
but it is still sending notifications when there is movment and you can see the 10 second video clips
but cannot log on to look at the cameras
is there any fix while im not at the property ??
Honestly you could try and reboot the base remotely ( in settings )... but IMO since you are away AND the cameras are recording...do you want to chance that it could all go out?
thanks your right leave sleeping dogs alone till i get back
wierd though
