You don't mention the color of the Internet (WiFi) LED but since it's blinking, I assume it's green. The Camera LED being off implies that either the base needs to be claimed or that no cameras are connected. Do you see the base in Settings, My Devices and can you access the various settings? If not, use the Add Device selection on the Devices tab to claim it. If you do see the base in your settings, try syncing a camera to it. Make sure the batteries are good - when you close the battery door, the LED should blink blue briefly to indicate power has been applied. Briefly press the base sync button (don't hold it for 2 seconds) and then press the camera sync button. The Camera should blink green and the camera LED should slowly blink blue. A successful sync will result in a rapid blue LED on the camera while a failure will be an rapid amber blink.
