Delay from time of notification to when video shows up.
Recently in the last week I have gone from getting my videos almost instantly after notification to now 3 minute delay or more. What do I need to do to get back to close to instantly. Thanks!
8 REPLIES 8
Prob outside of your control... it may be the far end
Unless you have changed your alerts from pushes to email.
Thanks for replying. I haven’t change anything regarding notifications sense I installed about 2 months ago. Delay is rather frustrating. Hopefully Arlo will correct soon !
Are you using Arlo Smart? Is the phone set to optimize battery for the app?
Using smart . Video set for best video not concerned about battery life as much as wanting best video.
I’m thinking I might have figured out what’s causing delay . I did change recording time to a fixed time and not while there is just motion. I was was having a problem with recording stopping while someone was on my front porch when they won’t move. Fixed time solved that problem. Thinking now that the extended time recording is the delay . Can’t record and send til done recording . Right ? But getting notification of activation like normal. Thus the delay I’ experiencing . Does this make sense.
Smart generally causes the delay, due to the need to upload the video for post-processing. Remove the camera(s) from Smart and immediate notifications should occur.
I had Smart on from day one and video came almost instantly. I was happy with time from notification to video til last week.
Might try taking one camera and setting it back to motion no fix time recording and see what that does .
