We're sorry, the database service is currently down. Please try again
We're sorry, Arlo is currently unavailable. Please try again later
Is anyone else getting this?
The new schedule setup threw me off for a second.... but in all it seems to work well.
Also the timer on the static shots was a great idea ( as opposed to the older plain date of last view )
Good work Netgear
On the new app how can you check cloud usage (how do you know how much room your recordings are using?).
Also so how do you get to the settings where you can choose either to delete old recordings to make room for new ones or not to record until you have manually deleted old ones?
Doesn't look like there is a storge limit for the first 7 days any more.I have been running 5 cameras fo a month now with 40-50 recordings on average a day and was not able to hit the max.
Netgear can you please advise. How do you check usage limit? Also if there is a lack of limit why were netgear still selling premier packages
Can someone from the netgear team please advise on my question above. The customer service team either put you on hold for over 30mins or have not been able to answer simple questions like above. Like other I have spent over 500 gbp on devices and packages and despite liking the product generally, find the customer device very poor
Fedmo98,
What is the behavior of your base stations internet LED? Where are you seeing this error message?
Probably won't help but try the other connection type, app or browser.
Can you get someone at home to check on your base?
Try a few things. Power off the modem, router and base. Power them back on in that order, allowing each one to start up (2 minutes or so) before doing the next one. If that doesn't help, try the reset button on the base until the LEDs flash amber. Let it start up and try again. You could try it on a neighbor's or friend's network in case it's something about your network. If still no go, swap the system at the store since the base may have an issue.
Briand0037,
Are you still seeing this behavior after trying the suggestions above?
Please let us know,
Yeah I am. Apparently the refurbished unit I purchased was not deleted from the previous owners account. Arlo Tech support is telling me I need to either return the unit to the store or via RMA to Netgear.
Either way it's a major PITA!
1  -
1  -
1  -
