Connessione Arlo BASE mediante wi-fi ?
Buongiorno!
Volevo sapere se Arlo Base potevo connetterla al router mediante wifi e non tramite cavo di rete.
grazie.
Google Translate says you wrote:
I wanted to know if Arlo Base could connect to the router via wifi and not via a network cable.
It is possible, and people have successfully reported doing so. You need a Wi-Fi bridge between your router and Arlo base station that allows the Arlo base station to plug into with an Ethernet cable. The Arlo base station can only connect via Ethernet to the Internet.
So, the connection is as follows:
Internet <--> Router <--> Wi-Fi Bridge transceiver < - - - > Wi-Fi Bridge transceiver <--> Arlo Base Station < - - - > Arlo cameras.
In the above:
- <--> is an Ethernet connection,
- < - - -> is a wireless connection.
