Connecting other brand cameras to Arlo
  • 2 Replies
  • 2835 Views
gebo
Need to move camera to new point but WIFI from base station does not reach. Have WIFI network using extenders/repeaters that are close to new point. How do I have camera connect to it?
 If you can't move the base you currently have your only solution is to get a second base And add the second base to the system....there  is no limit to any number of bases on any account level
brh
@gebo
If your extenders have a ethernet port to plug the second base station into then you are all set to go with a second base. The base stations must be connected to your wifi with an ethernet cable.
Brian
