Connected Arlo Q and want to add the Arlo Wirefree - can't see any instructions on linking the two?
  • 2 Replies
  • 2367 Views
Attitude34
Are the two sepearate or can I get them all to play nicely together?
Yes they play nice together but they are somewhat separate.
Q cams connect to your home wifi and the Arlos connect to the base only... They will appear in the same app/browser prgm but you have to arm & schedule them separately.  You can arm ALL the Arlo cameras as a group and then you have to Arm the Qs.
"It depends." (TM)
You can configure them so they're seen and controlled in one app but you can't set up modes/rules that include both.  Basically, each base station (consider the Q to have it's own built-in base) is separate and can't be merged with others.  You can add kudos to various ideas in the Idea Exchange (https://community.netgear.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange) to add emphasis.
