Clip length
I know the default is to record a 10 second clip upon detection of motion but if that motion was to continue is Arlo supposed to keep recording?
For example someone enters the back garden and walks around for one minute.
i dont know how long a break it takes but if after break it again detects motion it would create another 10 sec clip/
Nut by going into modes you can create/modify rule so that each cam will record up to 120 sec clips (can be set different for each cam)
reset between video clips is 10-20 seconds
