Cinstant Motion Trigger When no Motion
Dear friends: I am having a new problem with one of 6 Arlo cameras on my system. All of a sudden, it began to trigger and record when there is no motion present (or visible). I lowered the sensitivity to the lowest setting (a setting of 1), and it triggered 273 times last night. Upon review of the recordings, there is no Motion anywhere in frame. The only way I can stop this problem is to disarm the entire router. Up until yesterday, it worked flawlessly. Any ideas?
Take the 'bad' camera and remove the batteries....
Go to SETTINGS and use REMOVE DEVICE
Re-install batteries and resync the camera as if new... ( that will reset the camera and put all settings at default )
Take the camera and with the default settings arm it while it it facing a wall ( few ft away or so ).
If the false triggers continue, contact Netgear Support as there may be a problem with it
