× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification by Nov 30th, 2020 to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
Re: Chime Light Stays Amber After Reset
  • 6 Replies
  • 2837 Views
Highlighted
Arlo Chime light stays amber after reset.
Started the morning by finding that chime was not working,
Arlo app showed Chime as not synched, and to resynch device.
Tried resynching device and was not successful.
Removed device, reset it per the app instructions,
When trying to add device back to base station found the chime light would blink white for a while and then blinks Amber and finally stays a solid amber.
Any suggestions?
Highlighted
Hi @TRR33
What firmware version is your base station on? Can you try & reset the device a few times & then reboot your base station > try pairing process again. The Chime may be timing out from missing communication from the base station
Highlighted
I am having the same problem.
I have reset and reboot. Nothing seems to be working yet.
Any solutions?
Highlighted
Hi @Zach02
Is your base station up to date on the latest firmware?
It's showing it has 1.12.0.1_27940
What is the latest firmware?
Highlighted
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
Highlighted
I found that it paired nicely with the Sync button on the hub!
When going through the Arlo app as I've always done before, it didn't see it upon resets, reboots.
