Changing Registration Country (Arlo's)
I registered a country where there are no subscription plans apart from Basic. Subsequently I have changed countries to a supported one but do not see any options to change the original country-of-registration.
Is this possible at all?
Not directly, you may have to go thru Netgear Support
ChickenSqueeze,
This can be done by removing your Arlo devices from the original account and then creating a new account (using a new email address) in the new country. After you complete setup, you will be able to see subscription options for your current country.
