Changing IP
  • 1 Reply
  • 3043 Views
Aterzian
I am planning on changing my Internet provider in the next few weeks but I would like set up my system now to make sure everything works. Will I need to reconfigure everything once I change ?
A few people have had problems but theoretically it should be fine since the connection has nothing to do with an ISP or connection. Worst case you mag need to reset the base, remove all devices from Settings, My Devices and start over. If this is the case, be sure to note your settings and any modes, rules and schedule.
