Changed batteries but still says i need to change batteries
Changed batteries but system still says i need to change batteries and i am not getting any video
Open battery door , confirm the battereis are in correctly, close battery door and you should see the camera auto - resync
If not attempt to resync it ...
If still NG, reboot the base via the power button, check again...
If still NG, go to settings for that camera and use REMOVE DEVICE, then bring it bask as if new ( quick push on base sync button , not hold )
