Change or Remove two step logon authorization
  • 1 Reply
  • 1213 Views
rdilauro
Luminary
Luminary
Is there a way to change or remove the two step logon authorization?
I am going to have a situation where we have a master ARLO account that two people will have the ability to log into.  I will the the one doing it 95% of the time.  At some point, we will change the email address of the master.
But, now I realize if we do that the changed email address needs to be a real address.   Not a problem, I can create a new one.
But until then when
I log into currentmaster@somemail
I will be prompted for either a txt message or email sent
That would mean that the text would be set to the current owner of currentmastert@somemail or an email
sent to that address.     Is there a way to eliminate that step?  Reason is that when I log in, I dont want to wait
for that authorization step from the other person.  Many times I log at night and will not have that other person availalble.
What seems to happen often.  When I use the windows online version of myarlo, I will be dropped often I assume to non activity.  But logging on always requires this second authorization step.   However, when I log in from my IPHONE, this does not happen.  Is there a difference logging in from a computer vs iphone.
Ideally you'd be logging in to the main account from your phone, and would be able to set it up as trusted.
