Is there a way to change or remove the two step logon authorization?
I am going to have a situation where we have a master ARLO account that two people will have the ability to log into. I will the the one doing it 95% of the time. At some point, we will change the email address of the master.
But, now I realize if we do that the changed email address needs to be a real address. Not a problem, I can create a new one.
But until then when
I log into currentmaster@somemail
I will be prompted for either a txt message or email sent
That would mean that the text would be set to the current owner of currentmastert@somemail or an email
sent to that address. Is there a way to eliminate that step? Reason is that when I log in, I dont want to wait
for that authorization step from the other person. Many times I log at night and will not have that other person availalble.
What seems to happen often. When I use the windows online version of myarlo, I will be dropped often I assume to non activity. But logging on always requires this second authorization step. However, when I log in from my IPHONE, this does not happen. Is there a difference logging in from a computer vs iphone.
Ideally you'd be logging in to the main account from your phone, and would be able to set it up as trusted.
