Camera was acting odd after I put fresh batteries in it ... it said it was still dead , replace batteries ... so I put another set in ... said the same thing ... today , I look out my window and it was on fire ... thank God it wasn't inside or near something else or it would have burned down my house ... will never use arlo again
My first question would be what type/brand batteries were you using...??
Only one time in the years I heard of issues re heat were rechargeables of a china brand... that's why Arlo ONLY supported one brand of rechargable batteries for the Arlo HD.... they had built in safety features
You should contact Arlo support
Hi @C216
Thank you for your feedback. I would like to learn more about this situation. Can you please provide more detail regarding the batteries you were using with your camera.
Do you have a case number from customer support I can review? I would like to escalate this for you.
I have escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 42162145
