Cannot view local storage
- I have a doorbell and 2 cameras connected to the Arlo smarthub VMB5000. I have an arlo secure subscription for the doorbell and local storage for the two cameras.
In the arlo app I only see the recording of the doorbell in the feed but not the local storage.
How is this possible?
@BooIJ wrote:In the arlo app I only see the recording of the doorbell in the feed but not the local storage.
I am thinking you probably see "Feed" and "Dashboard" in the app menu (and not "Library").
If that is the case - local recordings are not in the feed. You access them
- going to the devices page
- selecting the smarthub
- selecting storage settings.
If you do see "Library" in the app menu, then you instead
- go to the Library page
- press the top center of the title page (likely says "cloud" or something similar)
- Then select the smarthub from the pulldown.
It is true. I find it at settings
